Aftermarket siren
lilboi
Copper - Posts: 126
Posted: August 09, 2004 at 2:49 AM / IP Logged
I just installed the clifford RSX 3.5. I think the siren isn't as loud as i want it to be. I'm wondering if I could add or replace the siren with a louder one. Is there anything special about this siren? Will a different siren work the same as this one?
Joen
Member - Posts: 13
Posted: August 10, 2004 at 1:19 AM / IP Logged
You need to add a relay first to add second siren-------
87 to two sirens
30 to 12V power
85 to ground
86 to alarm system siren output
lilboi
Copper - Posts: 126
Posted: August 10, 2004 at 2:07 PM / IP Logged
why is the wire coming from the alarm not enough power?
Joen
Member - Posts: 13
Posted: August 10, 2004 at 3:48 PM / IP Logged
Alarm unit siren output is not strong to drive 2 sirens.
If you are only replacing with deferent siren you don't need the relay.
Tuesday, July 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
