Help me get rid of the annoying vibration
vdubmk4
Copper - Posts: 175
Posted: August 15, 2004 at 11:39 PM / IP Logged
Yeah my redline is right around 6500 but it sucks cause my final drive ratio blows. VW dint account for ppl who swap out crap for performance parts on there 2.0 L engine models.
Fortune: You will continue to take chances, and be glad you did.
MBZ oe
Silver - Posts: 385
Posted: August 15, 2004 at 11:44 PM / IP Logged
Yeah, MB did a great job with the gear ratios in the 4 speed 722 automatic. Do you have shorter wheels and tires than stock? That would definitely affect your final drive gear ratio.
boom, boom, boom boom....
vdubmk4
Copper - Posts: 175
Posted: August 15, 2004 at 11:50 PM / IP Logged
Nah, if nething the overall size is bigger in diameter. I ottienger 18's paired with some Kuhmo Ecstas (not sure what size), but they fill the wheel well with just enough room to spare.
vdubmk4
Copper - Posts: 175
Posted: August 15, 2004 at 11:51 PM / IP Logged
Sorry "I have otteinger"
hurtado_roberto
Copper - Posts: 196
Posted: September 12, 2004 at 5:12 PM / IP Logged
Wasn't your oil temperature a bit high when you were going 150mhp in that picture?  Is that how it normally runs?
Poly Dollies
kfr01
Gold - Posts: 2,121
Posted: September 12, 2004 at 8:16 PM / IP Logged
MBZ oe wrote:
You would not need near that much. I would estimate 1 bulk pak/36sq ft of Dynamat Xtreme. Anything else, get 70sqft.
FYI:One bulk pak of Dynamat -X weighs 90lbs
A bulk pack of Dynamat Xtreme doesn't weigh anywhere near 90 lbs.  A bulk pack contains 9 18" x32" sheets.  There is no way a sheet of that size weights 10lbs.  I lifted 90 lb dumbells in the gym today and handled a bulk pack a few weeks ago.  They aren't even close.  Maybe you made a typo? ;-)
New Project: 2003 Pathfinder
MBZ oe
Silver - Posts: 385
Posted: September 13, 2004 at 1:23 PM / IP Logged
I don't know what I was thinking.  1 bulk pak is about 30-50lbs.  I'll be picking up 3 bulk paks next week for installs so I'll post the exact weight then.
Hurtado, did you mean my oil pressure? It is always at 3 bar when driving. When idling it sits a little lower.
hurtado_roberto
Copper - Posts: 196
Posted: September 13, 2004 at 3:34 PM / IP Logged
Are you sure that's the symbol for oil pressure?  Whatever it is I don't think it should be at the max but you were pushing your car to its limits.
Does the weight to the sound dampening material differ significantly with brand?  I can't accurally recall what the 100sq. ft. from e-bay weighed but it did feel like it was more than 30lbs.
B-quiet specifies on e-bay to be 0.3lbs/sq.ft.
Black Mat     .56 lb./ft²
Dynamat     .45 lb./ft²
Brown Bread     .40 lb./ft²
Poly Dollies
Page of 4
