1998 Dodge Ram 1500 Alarm/Remote Start Wiring Diagram
upjeeper
Member - Posts: 21
Posted: August 23, 2004 at 7:07 PM / IP Logged
has anyone got the wiring specs for a 1998 dodge ram 1500? I'm hoping to install my security/start unit this week. It looks like the 97 and 99 versions are different so i'm not sure which colors to use.
thanks in advance!
nate
auex
Platinum - Posts: 5,041
Posted: August 23, 2004 at 10:49 PM / IP Logged
There is a diagram section that would have the info you want, but since I already looked it up here.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
upjeeper
Member - Posts: 21
Posted: August 23, 2004 at 11:19 PM / IP Logged
awesome!
thank you, i looked but apparently not in the right place
auex
No problem.
upjeeper
Member - Posts: 21
Posted: August 27, 2004 at 5:40 PM / IP Logged
do you have any information how to tie into the lock/unlock wires? I can't find the "10 Pin Connector Driver's Kick Panel " for the life of me.
I think i've seen it said before that the 98 dodge rams use the 5 wire system, if that's true is there any other way aside from this
https://www.the12volt.com/doorlocks/page3.asp#5w
to wire the locks? like i said i can't find that stupid wire, i found it way up behind the instrument cluster, and was able to tap into that (i know it's cheating) but it would be a PITA to cut the wires and splice into both sides
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
