2005 Chrysler 300, remote start/airbag light
Big Dog
Gold - Posts: 1,265
Posted: September 15, 2004 at 11:36 AM / IP Logged
Has anybody had AIBAG light come on after doing r-start and WireMagic's method of doing 2nd ign and crank?
larkster
Copper - Posts: 98
Posted: September 15, 2004 at 12:30 PM / IP Logged
only done one.  the ignition circuit is the same as the caravan.  second starter wire PURPLE / brown negative with  180ohm resistor.  not sure what wiremagic says but i dont remember there being a second ignition wire.
jcap
Member - Posts: 41
Posted: September 15, 2004 at 11:59 PM / IP Logged
if you hooked up the wiring bypass as per wire magic method . the cruise control will not wokring also.
jcap
another-kelly
Silver - Posts: 618
Posted: September 16, 2004 at 12:16 AM / IP Logged
here's DEI's:
12volts
 lt. blue/red (15A)
 ignition harness
Starter pink/dk. green  +  ignition harness
Second Starter PURPLE / brown  -  ignition harness
Ignition pink/white  +  ignition harness
Second Ignition
Third Ignition
Accessory PURPLE / brown  -  ignition harness
CHRYSLER, 300, 2005, Second Starter
The second starter wire is negative trigger thru an 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1083 for wiring information.
http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1083.pdf
larkster
Copper - Posts: 98
Posted: September 16, 2004 at 8:14 PM / IP Logged
did one today again...cut PURPLE / brown wire measured it.  this wire does keysense 8.4k starter 180ohm and accessory 620ohm. i hooked up the second starter and the acc and everything works fine. no airbag light on and test drove cruise works fine...however i did have the check engine light come on...anybody else
extreme1
Silver - Posts: 1,070
Posted: September 16, 2004 at 11:40 PM / IP Logged
I use a DEI 456L resistance learning module for 2nd ign/start.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Monday, July 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
