Relay Chatter - Hatch door servo
charger69
Posted: September 20, 2004 at 7:45 AM / IP Logged
I'm bench testing 2 relays wired to flip flop pos/neg for a boat hatch actuator.  One relay works just fine, the other may chatter or not work at all.  If I remove the wires and test, it tests good.  Tried with a couple of different relays with same result.  I'm using the layout shown below.  What gives?
Relay Chatter - Hatch door servo - Last Post -- posted image.
Teken
Gold - Posts: 1,492
Posted: September 20, 2004 at 9:36 AM / IP Logged
How much holding current, and voltage are you applying to operate the relays?
As it sounds like there is not enough of one, or the other, to hold the relays open / close state.
Regards
EVIL Teken . . .
charger69
Posted: September 20, 2004 at 9:47 AM / IP Logged
Im using a 10amp battery charger for benchtesting.
charger69
Posted: September 21, 2004 at 6:46 AM / IP Logged
Thanks for the info Teken, power checked good but while I was there I re-checked all the leads.  Seems one of the crimp connectors had broken a wire and it was arcing causing the relay to chatter!
Teken
Gold - Posts: 1,492
Posted: September 21, 2004 at 4:10 PM / IP Logged
Good to hear things worked out.
Regards
EVIL Teken . . .
