89 S10 Standard dash to digital dash
box_of_fire
Posted: October 21, 2004 at 12:34 AM / IP Logged
Hello ...to keep this short I have a 1989 S-10 pickup that i am fixN up.........Question............It has a standard dash in it..I would like to put a digital dash in it. I am thinking that GM would have used the same sensors on both vehicles to save $$$$ so all it would take is to make an adapter to plug into the digital dash ????  Could it be that easy ¿
Ravendarat
Platinum - Posts: 2,806
Posted: October 21, 2004 at 7:58 PM / IP Logged
Strait swap man, dont even need to change the plug
box_of_fire
Posted: October 22, 2004 at 12:03 AM / IP Logged
No the plugs are not the same.... There are also more wires.....my standard dash has 15 wires the digital I was looking at has 18... Standard dash has no tach or ABS.. The digital has both. The tach needs 2 wires and i think the ABS would only need 1.. So that takes care of the Xtra 3 wires... I hope.............................Has anyone done this before? I would hate to shell out $200+ and have it not work :(
Ravendarat
Posted: October 22, 2004 at 12:41 AM / IP Logged
Hmm, I own a 89 s-10 and did the swap but my anolog dash had a tach so it was a strait swap, same plugs and all. I am surprised gm went through the cost of making seperate harnesses. Either way, the swap is definatly possible and if you get a wiring diagram you can easily crossreferance the plugs and attach the new harness. Go to a GM dealler and ask to see their master manual for the vehicle and they will let you look at the book and copy down the wiring codes you need.
box_of_fire
Posted: October 23, 2004 at 1:47 AM / IP Logged
I talked with a guy in Canada that rebuilds em and he said that i can make an adapter to make it work...Will mail this thing off next week and get it rebuilt so it will be a few weeks before i get to hook it up...I will post back when i do and let ya know if i got it to work or not...thanx for your help Ravendarat
Tuesday, August 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
