Filler question for fiberglass panels
sandiegolexus
Posted: November 07, 2004 at 2:29 PM / IP Logged
hello. been reading for a while and wanted to finally ask a question. i just finished glassing my spare tire well and it came out great. i am in the process of doing the speaker mounting portion of the install. after i get the shape made with fleece and resined i intend to put many layers of fiberglass on the top of the fleece for strenth. oh yeah i will be running three 10w6v2. after all the glass cures i will be ready to start smoothing it out for paint. here is my question. do i first apply generious amount of duraglass and smooth it all out and then aplly the rage gold to get the final finish. or will the duraglass be plenty to get the desired smooth finishe for paint. also is duraglass the filler with the fiberglass hairs in the filler. if so can i use any brand of the stuff or is duraglass the way to go.
thanks
dennis
auex
Platinum - Posts: 5,041
Posted: November 07, 2004 at 6:17 PM / IP Logged
You don't really need generous amounts of either. Just enough to smooth the surface out. If you use too much then you increase the chances of it cracking.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
realitycheck
Silver - Posts: 751
Posted: November 07, 2004 at 7:56 PM / IP Logged
I just got finished using both of the products you mentioned, they absolutely rock by the way.  The duraglas use it firsty of course sand it down, it doesnt have hairs in it I think it was more of a dust glass in the filler.   The rage gold I just put on tonight and sanded down that stuff is awesome sanding it just sands away with ease.  As for me the duraglas and rage gold is what I will use from now on.
CarAudioHelp
Copper - Posts: 198
Posted: November 08, 2004 at 8:35 AM / IP Logged
Duraglass is the USC brand of fiberglass reinforced body filler. There are two types of it, short strand and long strand. Duraglass is short strand. I've used it and it works fine but my supplier carries Evercoat products so that's what I use. The Evercoat short strand is Everglass and the long strand is called Kitty Hair. You'll want to use the short strand type.
HottAccord
Silver - Posts: 247
Posted: November 11, 2004 at 9:46 PM / IP Logged
I have yet to use Duraglass, but I heard a lot of good thing about it and how strong it can be.  You can also use it to sharpen up edges on custom enclosures to make the install look a little cleaner.  Filler question for fiberglass panels - Last Post -- posted image.
Im a fiberglass whore!!
