Pioneer navigation?
derby98
Member - Posts: 14
Posted: November 16, 2004 at 2:28 PM / IP Logged
Need a bit of advise... I have a 05 Ford Econoline work van that came in to have a navigation installed. On the 2005 there is NO VSS wire as it uses a fiber wire........ I double checked with Rostra.
I was told that Pioneer has a nav system that does NOT require a VSS input?
Is that true? Anyone have a model # or any advise?
Customer wants indash unit w/ flip screen.
boostedcivic
Member - Posts: 37
Posted: November 16, 2004 at 6:31 PM / IP Logged
I have heard that youn can run a navi system without the VSS wire attached but the position on the map is not as acurate. Thats all I know about it.
Jason
derby98
Member - Posts: 14
Posted: November 16, 2004 at 6:44 PM / IP Logged
I tried installing a Audiovox Nav 5000 & the screen does not move without the VSS hooked up. I installed the Audiovox in a 2004 Ford Ranger with  vss hooked up & it works fine.
Longshot421
Member - Posts: 7
Posted: November 18, 2004 at 4:10 PM / IP Logged
According to the Pioneer manual for the AVIC-N1, you CAN run it without the VSS, but the position update is not as accurate.  You can buy a spearate speed sensor in instances where the VSS is not accessible or in your case, not useable.  Check www.avic-n1.com and look at accessories.
Tuesday, November 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
