12 volt constant
fooser
Member - Posts: 15
Posted: December 18, 2004 at 12:28 AM / IP Logged
Im installing a DEI Vallet 554r, a GMDL-BP, plus power door locks and power windows in 2003 GMC Sierra.  My questions is this
I have 7 leads that require a (+) 12 volt constant connection, am I okay tapping into the 12 volt constant that is located in the ignition harness or do I need to run a new lead off the battery for these connections?  Or is there a place in the trucks fuse bax that I can tap into for this?
JRoscoe
Member - Posts: 29
Posted: December 18, 2004 at 5:07 PM / IP Logged
It shouldnt be a problem to run one 8 or 10 awg of the battery and split off of that as long as each of the 7 leads are fused after splitting.
fooser
Member - Posts: 15
Posted: December 19, 2004 at 11:26 AM / IP Logged
what size of fuse should i use?
JRoscoe
Member - Posts: 29
Posted: December 19, 2004 at 11:33 AM / IP Logged
that depends on the current draw.  use a multimeter to determine this
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
