Avalon Break switch for remote start
axpo
Posted: December 31, 2004 at 12:57 AM / IP Logged
Hey all,
I am in the process of installing a Bulldog remote starter on my 2000 Avalon, and it has gone rather easily thus far, until I got to the very last wire to connect, which needs to attach to a "+12 volt wire at the break switch".
The wiring chart on their site says it is red with a blue stripe, and the manual says it should test positive only when the break peddle is pressed.
I found a RED / blue near the fuse box that is negative always, and a RED / blue near what i think is the break switch, but it is positive always.
Now I am not sure if i am even testing hte right wires,  I can't physically get anywhere near what i think is the 'break switch.'
Avalon Break switch for remote start - Last Post -- posted image.
The manual says that if it is not there, then I need to attach the wire to the rear break light, this seems like more of a hassle for me to do. Avalon Break switch for remote start - Last Post -- posted image.
Does anyone know if I can connect to the wire that runs to the rear break light under the dash or in the kick plate or someplace else?
I have now spent many hours looking for this wire,
Any ideas?
Anyone else have have a problem like this?
Thanks,
George
2000 Avalon XL
KarTuneMan
Platinum - Posts: 7,056
Posted: December 31, 2004 at 1:18 AM / IP Logged
Your brake wire is located in the drivers kick. in a grey plug, its GREEN / WHITE (+) pos.
Its there trust me!!
Your parking light wire is there too, in a blue plug its green (+) Pos.
KarTuneMan
Posted: December 31, 2004 at 1:19 AM / IP Logged
Your brake wire is located in the drivers kick. in a grey plug, the wire is GREEN / WHITE (+) pos.
Your parking light wire is there too, in a blue plug, the wire is green (+) Pos.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
