Installing driving lights
speed_pıro
Posted: January 01, 2005 at 1:18 PM / IP Logged
I just got some new driving lights for my 1st gen Neon, can anyone tell me how to wire these and install them? Thanks.
gcorrea
Silver - Posts: 436
Posted: January 02, 2005 at 1:31 AM / IP Logged
how do you want them to come on. switch on manually with your parking lights or maybe on all the time through your ignition switch. there are many options.
gcorrea
gcorrea
Silver - Posts: 436
how do you want them to come on. switch on manually ,with your parking lights or maybe on all the time through your ignition switch. there are many options.
gcorrea
gcorrea
Silver - Posts: 436
how do you want them to come on. switch on manually, with your parking lights or maybe on all the time through your ignition switch. there are many options.
gcorrea
gcorrea
Silver - Posts: 436
Posted: January 02, 2005 at 1:34 AM / IP Logged
how do you want them to come on. switched on manually, with your parking lights, or on all the time through your ignition switch, you have alot of options.
gcorrea
gcorrea
Silver - Posts: 436
Posted: January 02, 2005 at 1:35 AM / IP Logged
damn, must of hit it a few times.sorry.
gcorrea
speed_pıro
Posted: January 02, 2005 at 10:43 PM / IP Logged
I want a switch independent of my normal headlights.
speed_pıro
Posted: January 03, 2005 at 12:16 AM / IP Logged
Ok my main problem is that my instructions say to connect one side of the switch to the relay and the other should be tapped into the cable for my headlights so that the driving lights can only be turned on when the headlights are on, which I don't want. I want to be able to turn them on whenever, so where should I connect the other side of the switch?
forbidden
Platinum - Posts: 5,354
Posted: January 03, 2005 at 2:34 PM / IP Logged
Wire the switch and relay according to these instructions.
- ground one side of switch.
- wire other side of switch to pin 86 on relay.
- wire pin 87 on relay to + on each driving light.
- wire pins 85 and 30 together to +12v. Fuse this line with a 15 amp fuse.
Use a Bosch relay (preferred) with 5 pins for this. Do not use pin 87a.
Texas Dodge
Member - Posts: 6
Posted: January 14, 2005 at 10:03 AM / IP Logged
I would connect the switch to your parking lamp wire. That way you can have them on with your low beams and high beams as well. Plus when you turn your parking lamps off, the driving lights will also go off and you won't come back out with a dead battery if you forget to turn them off.
