Clifford matrix rsx3.5
Falcon 1
Copper - Posts: 130
Posted: January 15, 2005 at 7:20 AM / IP Logged
The only thing that came in the box is a 3pin connector but its attached to a module(relay pack) which has an additional 5 wires coming from it. The manual does not say anything about it?
Do it right the first time, only a doctor can bury his mistakes.
kgerry
Platinum - Posts: 3,455
Posted: January 15, 2005 at 11:59 AM / IP Logged
the bag it came in should have had an instruction sheet.... it is simply a 451M dual relay module... you dont need to add anything...it already has two micro-relays in the little black box...
and the BLACK/ white neutral safety wire gets connected to the on/off toggle valet switch included in the box.... one wire goes to ground and one wire goes to the BLACK/ white wire in the harness....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Falcon 1
Copper - Posts: 130
Posted: January 15, 2005 at 1:08 PM / IP Logged
kgerry that is the problem I have the bag contained no instructions does someone have a schematic for this I checked Clifford website and could not find anything.
Everything else is working as it should the only thing left is the lock and unlock connections.
