Bulldog Remote start
Astro4X4
Posted: October 25, 2002 at 11:43 PM / IP Logged
Hello all,
  I'm installing a Bulldog remote starter/keyless entry in my wife's 1999 Pontiac Transport.  All went well, with the exception of the brake input.  The cold side of the brake switch has 600 Mv on it and is triggering the remote start shut down.  If worst comes to worst I will put a dedicated micro switch on the pedal for it, but why does the cold side have power on it?.  Would this somehow be related to the BCM?
TIA
Dave
Platinum - Posts: 12,488
Posted: October 26, 2002 at 9:00 AM / IP Logged
Did you grab the WHITE wire at the switch for this connections ?
Astro4X4
Posted: October 26, 2002 at 10:00 AM / IP Logged
Yes got the white wire.  I got it figured out and had to put a diode in the white wire.  The van has auto on headlights, when they were on I would get around 600 Mv on the cold side but it was dead when they were off.
So now, what is better, tach or tachless?
TIA
Dave
Posted: October 26, 2002 at 8:43 PM / IP Logged
Tach is recommended. Don't trust the tachless modes.
Player69
Silver - Posts: 504
Posted: October 27, 2002 at 8:44 PM / IP Logged
If you have power on the white wire at the brake switch when the park lights are on something is wrong.  Most likely the problem is a bad tail light bulb.  It filliment for the tail lights is likely broken and shorted to the brake light filliment.
Astro4X4
Posted: October 27, 2002 at 9:18 PM / IP Logged
I thought the same but all bulbs check out fine.
Thanx
Dave
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
