How to install a Chirper
bbtaco
Copper - Posts: 119
Posted: November 03, 2002 at 7:31 PM / IP Logged
 I have an Ungo RS151 remote starter/keyless entry installed in my 2002 Toyota Tacoma pickup. I would like to have it chirp when locking or unlocking the doors. It has a wire for the horn honk function(not hooked up) Would all  I need is a SPDT relay and a small speaker(piezo?).
Moderator - Posts: 12,488
Posted: November 04, 2002 at 8:23 AM / IP Logged
Hook up a siren with a relay to the light flash wire, not the horn honk. This will give you what you wanted above in your post.
bbtaco
Copper - Posts: 119
Posted: November 04, 2002 at 5:55 PM / IP Logged
Thanks for the information. Would you happen to know where I could get a schematic showing the proper wiring for the relay and siren?  thanks again.
Posted: November 05, 2002 at 12:45 AM / IP Logged
Hook up a 30/40 amp 5 pin relay in this configuration:
  • 86 : GROUND
  • 87 : Constant 12 volts (FUSED)
  • 85 : WHITE wire from RS151 ( light flash wire )
  • 30 : (+) wire side of siren. ( Ground the other siren wire to chassis )
  • 87a: NOT USED
bbtaco
Copper - Posts: 119
Posted: November 05, 2002 at 7:47 PM / IP Logged
Great. Thanks !
Posted: November 06, 2002 at 12:48 AM / IP Logged
No problemo
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
