Tach Install Problem 04 Accent
04Hyundai
Posted: March 07, 2005 at 7:20 PM / IP Logged
I have hooked up a Summit tach in my 04 Accent. I tapped the grey wire pin #8 off of the ECU for my signal. The tach does work but it doesnt read the same as my stock tach any ideas why?
Thetruth
Posted: March 07, 2005 at 8:42 PM / IP Logged
I had a similar problem with my 2003 accent i had a Sunpro guage and had the same problem mine had a difference of arounb 300 rpms between the two. I taped into the gray wire behind the guage cluster but its the same thing. I think i had the problem because i had a cheap guage.
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
