avic N2 problems in 2004 accord
Sanjose956
Posted: March 22, 2005 at 2:24 PM / IP Logged
I resently installed a AVIC N2 in a 04 accord. THe Safety warning comes on every time the unit is turned on. I is for the E brake. But the E brake is connected Properly. And the unit is not access ing the different views on the map. Any one know what might be causing this problem
auex
Platinum - Posts: 5,041
Posted: March 22, 2005 at 6:01 PM / IP Logged
That is a new built in SAFETY feature. There currently is no bypass so you are going to have to be legal. Also when in motion some nav features are inaccessible, less of a distraction.
Check the sig.
If you are having other problems then not being able to see the video while in motion please mention them.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
jtrevill
Member - Posts: 20
Posted: March 22, 2005 at 6:32 PM / IP Logged
I think he is experiencing different problems than you are hearing.  I installed mine last night with the same symptoms.  I hooked up the parking brake cable, but it still boots up stating that the parking brake cable is not correctly installed...    I can hit OK and it goes away and everything works as it should with no limitations (until you drive), but how do you correct that error screen?
Thanks!
jtrevill
Member - Posts: 20
Posted: March 24, 2005 at 11:19 AM / IP Logged
As a follow up, I can't play video even while parked!  It goes to a black screen immediately.  I know it's playing, as I can hear the sound, just no video.  Parking brake is on, and in the settings, the unit sees that the parking brake is on.  The vehicle isn't moving, and it says that vehicle speed is 0.  Any ideas?  THanks!
12v_rep
Copper - Posts: 188
Posted: March 24, 2005 at 11:36 AM / IP Logged
Hit you ENT button and see if that helps.
jtrevill
Member - Posts: 20
Posted: March 24, 2005 at 1:46 PM / IP Logged
Thanks - that fixed the problem!
12v_rep
Copper - Posts: 188
Posted: March 24, 2005 at 2:07 PM / IP Logged
Glad I could help!!!
Tuesday, November 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
