05 Mercury Sable RS ?
Ren92
Copper - Posts: 56
Posted: April 05, 2005 at 8:14 PM / IP Logged
Does anyone have the wire colors for an 05' Sable? I have everything but the tach but it would be nice have the rest.
Ren92
Copper - Posts: 56
Posted: April 05, 2005 at 9:57 PM / IP Logged
anybody????
Ren92
Copper - Posts: 56
Posted: April 05, 2005 at 11:33 PM / IP Logged
will the 555F work for this car also?
clank
Member - Posts: 35
Posted: April 05, 2005 at 11:39 PM / IP Logged
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) +  steering column
Turn Signal(R) wht/lt blu (F), org/lt blu (R) +  steering column
Reverse Light BLACK/ pink  +  kick panel, harness to rear
Door Trigger see notes  -  GEM, 26 pin plug
Notes: The LF door trigger is yellow/black in pin 5. The RF door trigger is gray/red in pin 19. The LR door trigger is lt. GREEN/ YELLOW in pin 20. The RR door trigger is pink/lt. blue in pin 7. Use all four wires and diode isolate each.
The GEM (Generic Electronic Module) is part of the SJB (Smart Junction Box) to the left of the steering column. It has three plugs on the bottom.
Dome Supervision BLACK/ lt. blue  +  SJB, top plug, pin 22
Notes: The SJB (Smart Junction Box) is the fuse/relay box to the left of the steering column. It has three plugs to the left of the fuses.
Trunk/Hatch Pin see notes  -  see notes
Notes: On the sedans use BLACK/ pink at the light in the trunk. On the wagons use WHITE/ purple at the GEM, 26 pin plug, pin 21.
Hood Pin tan/lt. green  -  GEM, 26 pin plug, pin 17
Notes: The GEM (Generic Electronic Module) is part of the SJB (Smart Junction Box) to the left of the steering column. It has three plugs on the bottom.
Trunk/Hatch Release purple / YELLOW  -  GEM, 26 pin plug, pin 3
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm pink/white  -  GEM, 26 pin plug, pin 4
Disarm No Unlock see factory alarm disarm
Tachometer NOT red  ac  ign coil/coil pack or fuel injector
Wait to start N/A
Brake Wire RED / lt. green  +  brake pedal switch
Parking Brake lt. green  -  switch or GEM, 26 pin plug, pin 1
Horn Trigger dk. blue  -  column or SJB, bottom plug, pin 1
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
05 Mercury Sable RS ? - Last Post -- posted image.
Immobilizer Bypass Module:Required: YesType: SecuriLockPart #: 556S, 556U, or 555U
Notes: N/A
shocker
clank
Member - Posts: 35
Posted: April 05, 2005 at 11:43 PM / IP Logged
 2005 / Remote Start
[PRINT THIS PAGE]
12volts lt. GREEN/ purple (40A)  +  ignition harness
Starter RED / lt. blue  +  ignition harness
Second Starter N/A
Ignition RED / lt. green  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW  +  ignition harness
Second Accessory BLACK/ lt. green  +  ignition harness
Keysense BLACK/ pink  -  ign harn or GEM, 20 pin plug, pin 17
Power Lock pink / YELLOW  -  GEM, 26 pin plug, pin 18
Power Unlock pink/lt. green  -  GEM, 26 pin plug, pin 6
Lock Motor pink/black  5wi SJB, top plug, pin 3
Unlock Motor RED / white  5wi SJB, top plug, pin 2
Parking Lights+ brown
shocker
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
