Impluse-RES Add-on
pincky
Member - Posts: 25
Posted: November 13, 2002 at 6:45 PM / IP Logged
Hi I Have a Impluse-RES Add-on Remote start for factory keyless/alarm
Its currently installed on a 2001 Chrysler sebring Coupe. I have the transponder Kit installed and the remote start works perfecty!! (installed myself). But i do have 1 question, does the wire that goes to the parking lights need to be on a relay?? becasue i hooked it up to the parking light wire (pink/black), and when i activate the remote start.. she starts then it just shuts off.. and it restarts fine and then shuts off..but when i unhook that parking light wire the car starts normaly and it runs fine...
what is the problem...and If i do need a relay can u please tell me what wire goes where.
the instruction manual says it does not require a relay..
but i value your guys opinions on here so i will take your guys adivce 1st! Thanks!!!
pincky
Member - Posts: 25
Posted: November 13, 2002 at 6:48 PM / IP Logged
Here is an Addon to the 1st msg
what it Exctally says on the manual
WHITE=(Parking Lights Output.(12V+15A,UP To 50A Inrush. Connect to one of the parking Lights of the car).
Thanks!!!
Player69
Silver - Posts: 504
Posted: November 13, 2002 at 6:56 PM / IP Logged
Your white wire should be hooked up to a BLACK / YELLOW wire in the drivers kick panel.  The black yellow should be +12v when the park lights are on and ground when they are off.  Test with a DMM.
Platinum - Posts: 12,488
Posted: November 14, 2002 at 5:29 AM / IP Logged
The PARKING LIGHTS +|grn/wht or pnk/blk is located  low in drivers kick panel. These wires test the way player69 says above, no relay necessary. Make sure you test the output of the RES-R to ensure that it is in fact outputtinh a (+) signal when remote starting.
pincky
Member - Posts: 25
Posted: November 14, 2002 at 2:16 PM / IP Logged
what do u mean Low in the drivers kick panel? Like is it on a plug or something?
Player69
Silver - Posts: 504
Posted: November 14, 2002 at 2:49 PM / IP Logged
He means low as in probably close to the floor boards. These will be the wires going to the rear of the car in a big harness.
pincky
Member - Posts: 25
Posted: November 24, 2002 at 11:42 PM / IP Logged
Thanks alot for the answer i found that wire and it was a Pink/Black wire and it works perfectly!!! Thank u!!
