How many subs should I run?
possessed007
Member - Posts: 16
Posted: April 24, 2005 at 1:18 PM / IP Logged
jeffchilcott wrote:
you can run 2 d2 subs perfectly,   wire the 2 coild in series to get 4 ohm per sub then wire the 2 sub in parrallel to get a 2 ohm load,    this would be perfect for your amp and subs.    If you wired all 3 subs like this you would get a 1.33 ohm load, below the 2 ohm rating..I can not recommend doing this unless you called PPI and checked to see if the amp could handle it
Welll I think I will change the amps...I have 2 PCX-2200 I can purchase one more and run one for each sub which will give me 1 x 800w at 2Ohms each amp.....of course 800w is a bit too much so I would have to lower the gain but it will run the amp cooler.....
possessed007
Member - Posts: 16
Posted: April 24, 2005 at 11:59 PM / IP Logged
If I ran a PPI PCX-2400 Bridged at 4 Ohms 1600w......can I run it with 3 JL Audio 10W6v2-D4............?
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
