Porting into rear deck
geepherder
Platinum - Posts: 3,668
Posted: May 04, 2005 at 8:11 AM / IP Logged
I'm doing an older mercedes for a customer as well.  I'd avoid the bandpass as it probably won't sound any good- too boomy over a small bandwidth.  Removing the first aid kit is what I would suggest as well.  I'm going to build a grill to go in it's place when he comes back this weekend.
1stimer
Member - Posts: 6
Posted: May 04, 2005 at 1:05 PM / IP Logged
Can you please let me know if sufficient bass is getting into the cabin from the removal of the first aid tray?
Thanks...Randy
1stimer
Member - Posts: 6
Posted: May 04, 2005 at 1:06 PM / IP Logged
What model mercedes?? What did you do for the fronts? door mount the or pods? Can you please let me know if sufficient bass is getting into the cabin from the removal of the first aid tray?
Thanks...Randy
1stimer
Member - Posts: 6
Posted: May 05, 2005 at 3:14 PM / IP Logged
I just wanted to mention that besides the installer that reccomended a bandpass enclosure ported into the rear cabin, two members of the image dynamics forum have also suggested this is the reccomended enclosure and procedure to get bass into the cabin of my vehicle with an idq-10. They said that it is the only circumstance in which a bandpass enclosure will sound better than the alternatives. I am still going to try and do a sealed box with the first-aid tray removed, but I think porting into the cabin may be the best alternative in a few select cases.
geepherder
Posted: May 05, 2005 at 8:14 PM / IP Logged
I think it's coming in either tommorrow or Saturday.  I'll be sure to let you know how it turns out.
