2002 Impala Power Lock
vestjam
Posted: May 15, 2005 at 9:41 PM / IP Logged
Hello, I'm a "do it yourself" type and I know just enough to be dangerous with vehicle electronics.  Plus I'm too cheap to pay to have it done.   I wanted to install a RS with Alarm in a 2002 Impala.  I've located all my wires and learned that the lock/unlock use the same wire.  The Note states "Lock requires a negative tripper with a 470 ohm resistor in -line.  Unlock is negative trigger.  Must use relays."      The RS/Alarm sends a negative trigger.
How do I complete the wiring with the relays with resistor?  Any and all help is welcome.
Bnluis
Silver - Posts: 578
Posted: May 15, 2005 at 10:23 PM / IP Logged
just like this, Just change the resistor value. Make sure the resitor goes on the lock relay.
2002 Impala Power Lock - Last Post -- posted image.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
mo12v
Posted: May 16, 2005 at 8:22 AM / IP Logged
................Somthin's BURNIN'....................................
Better LOOK at that Relay Post again................
That is for POSITIVE Pulse...............
Change PIN's 87 to GROUND
PIN's 86 & 85 go to Constant 12 Volts.......
MO
Bnluis
Silver - Posts: 578
Posted: May 16, 2005 at 9:35 AM / IP Logged
Correct. I totally ovel look it. late night.,
Read  mo12v post.
Luis
Sound Waves
vestjam
Posted: May 16, 2005 at 7:33 PM / IP Logged
Thanks for the information....  I'll let you know how it turns out.
One more quick question.   Is it necessary to disable the factory door lock/unlock  (BCM) when the alarm/RS is being used?
mo12v
Posted: May 16, 2005 at 11:03 PM / IP Logged
NO
MO
