Rather long Speaker wire lenth vs Gauge
robb420in323
Copper - Posts: 101
Posted: May 23, 2005 at 8:40 PM / IP Logged
Hi everyone. I was wondering how thick of speaker cable should I use for a 55Ft run..
The load will be 225watt Max @8 ohms
Thank you in advance.. I looked thru all the calculators. but i couldnt find the speaker table.
Robb
Hunter S. Thompson for sheriff
stevdart
Platinum - Posts: 5,816
Posted: May 23, 2005 at 10:01 PM / IP Logged
Use Ohm's Law to find amperage I = sq rt (P / R ).  225 / 8 = 28.  The square root is 5.3.  So 5.3 amps is the current the wire has to be able to carry.  Not much, due to the high impedance and low wattage.
Here's a great calculator for that.  You can see that with using 16 gauge wire the decibel loss is less than half a decibel, which is an inaudible result.
sedate
Silver - Posts: 1,173
Posted: May 23, 2005 at 10:10 PM / IP Logged
55ft run?  What? are you doing?
Poormanq45
Silver - Posts: 597
Posted: May 24, 2005 at 9:42 AM / IP Logged
For that long of a run go down one, possibly two for safety, guages.
To be safe I'd go with 12awg
Francious70
Silver - Posts: 629
DYohn
Moderator - Posts: 10,741
Posted: May 24, 2005 at 9:51 AM / IP Logged
Stevdart is correct.  No need to use anything larger than 16 AWG.
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
