Cold Solder
mr-allenp
Member - Posts: 19
Posted: May 28, 2005 at 12:39 PM / IP Logged
How good are these Cold Soldering units being sold out there that uses 4 AA batteries? They are said to immediately get hot and then after it immediately turns cold as well. I am planning to get one to use for my first install which i am planning to do in the very near future. I just want to know if it's worth the money or I would just go for the old corded solders. I hope someone would give me an insight. Thanks
geepherder
Platinum - Posts: 3,668
Posted: May 28, 2005 at 7:18 PM / IP Logged
Don't waste your money.  I've heard nothing good about them.
KarTuneMan
Platinum - Posts: 7,056
Posted: May 28, 2005 at 7:55 PM / IP Logged
It s ideal for the little tiny stuff they show on the tube....My mom got me one for christmas last year.....It NO GOOD for anything larger that say 3 hairs thickness.... For your soldering iron to use on your install....get a HOT one. A good electric one. Not the gas ones.....not hot enough, quick enough!! Im sure someone out there will tell me Im wrong....all I can say is, every install I do, all connections are soldered, I solder more than most.
soundman65
Member - Posts: 14
Posted: May 29, 2005 at 1:55 AM / IP Logged
its not a good idea to use those 'cold heat' ones on sensitive components, because it actually generates a current from one of its contacts to the other in order to heat up so quickly
thepencil
Gold - Posts: 1,526
Posted: May 30, 2005 at 9:57 AM / IP Logged
My $18 plug in the wall solder is better than that. The mosquito wire cord is just a small nuisance. Once plug in and heated up. It works all day long.
Be careful whose advice you buy, but be patient with those who supply it.Cold Solder - Last Post -- posted image.
Wednesday, August 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
