Remote control Work light
thetruckbuilder
Posted: June 13, 2005 at 1:12 AM / IP Logged
Hi all, I have just finished building a new truck body for a customer and it has hydraulics fitted to it that are controlled by a remote control. The remote control has 8 functions. Function 1 & 2 control 1 hydraulic cylinder in each direction and so does function 3 & 4 and 5 & 6. All of the functions are a momentary function. Now function 7 & 8 are also momentary but the customer has asked me if I can use function 7 to turn the work lights on, then turn them off again with the same button. The same goes for function 8 except for that it will turn on and off the traffic warning lights. Now keeping in mind that this truck is a 24volt system and the remote is also a 24volt system, what kind of help can anyone give on relays for this operation. I am very limited with room because all of this is to be mounted under the passenger side seat and I think a lot of relays and diodes are out of the question. The remote is also positive trigger not negative as in most cases.
Thanks in advance.
davidosand
Member - Posts: 36
Posted: June 17, 2005 at 9:13 PM / IP Logged
how about low profile Solid State relays. Check out this link... http://www.idec.com/Products/ENG/Relays/RelayRSS.html
thetruckbuilder
Posted: June 17, 2005 at 9:55 PM / IP Logged
Thanks for the Info. I will look into that.
hotwaterwizard
Silver - Posts: 1,350
Posted: June 18, 2005 at 12:50 AM / IP Logged
You need a Toggle Latching Relay.
Potter & Brumfield #S89R5ABC1 . . . Contacts 15 Amps 125/250 VAC resistive load. For each input pulse to coil, a latching toggle mechanism flips the position of a microswitch's wiper arm to low, high etc. Coil 120 VAC, 220 ohms, 75 mA. 0.187 quick connect terminals. Size 2.7 x 1.73 x 2". UL Listed, CSA Certified. New.
http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_Code=TM94RLY2590&Category_Code=RLY
Remote control Work light - Last Post -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
thetruckbuilder
Posted: June 18, 2005 at 1:07 AM / IP Logged
Thanks for the help John, I will definately look into that .
It looks like it may fit under the seat as there will be 2 of them needed to do both sets of lights.
hotwaterwizard
Posted: June 18, 2005 at 5:20 PM / IP Logged
Here are More
toggle relay
http://www.electrodepot.com/a4757.htm
http://www.attr.com/x10/a4758.htm
Stockton California
