24V Relay
dragginaccord
Member - Posts: 7
Posted: June 13, 2005 at 3:01 PM / IP Logged
Can i do this with your normal SPDT bosch style relay?
85 - (-)alarm trigger
86 - 12v constant
30 - 24v from hydraulic system
87 - 24v to hydraulic solenoids to activate pump.
any help is much appreciated......i figured the 12v and the (-) would work as a team and the 24v would pass right through without damaging the relay but i could be wrong.
Montrealler
Copper - Posts: 155
Posted: June 13, 2005 at 3:50 PM / IP Logged
Yes you can do this but you must respect the proper Amp ratings. Most of the time 30 amps is the maximum allowed
ff-mike
Copper - Posts: 199
Posted: June 13, 2005 at 4:17 PM / IP Logged
and generally that 30A rating is at 12vdc, and may change to a lower amount at a higher voltage
dragginaccord
Member - Posts: 7
Posted: June 13, 2005 at 4:29 PM / IP Logged
Thanks for the help......the 24v output will only be activating a larger solenoid so the amp draw will be very little.
hotwaterwizard
Silver - Posts: 1,350
Posted: July 01, 2005 at 12:57 AM / IP Logged
Monday, August 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
