nissan pulsar gtir 1990
kengtir
Posted: June 16, 2005 at 11:10 AM / IP Logged
im looking for the wirering diagram for fitting an alarm help in this matter would be helpfull cheers all
hope to get better
thepencil
Gold - Posts: 1,526
Posted: June 16, 2005 at 12:56 PM / IP Logged
That is the only year I have avaiable for you.
DIRECTWIRE™ WIRING INFORMATION - NISSAN / PULSAR / 1989 / Security
12volts BLACK/ red    +   ignition harness
Starter BLACK / YELLOW    +   ignition harness
Ignition BLACK/ white    +   ignition harness
Power Lock add actuators
Power Unlock add actuators
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ GREEN/ black      steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger yellow/purple    -   kick panel
Dome Supervision
Trunk/Hatch Pin RED / black    -   light or sw. in trunk
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer RED / white   AC   at instrument cluster
Horn Trigger GREEN/ black    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.nissan pulsar gtir 1990 - Last Post -- posted image.
