2002 toyota tacoma car security
jpet1192
Member - Posts: 15
Posted: July 08, 2005 at 5:45 AM / IP Logged
I put an alarm in my friends 2002 toyota tacoma. I found the lock / unlock wire with no problem. The vehicle has the child safety lock system. I was wondering do I need to worry about interfacing with this system. any advise would help me a great deal.
thank you
Powermyster
Silver - Posts: 962
Posted: July 08, 2005 at 6:07 AM / IP Logged
i dunno weather its the same. but i was looking at a corolla that had a system like that. its a seperate unlock wire also neg.  you just loop onto it. but use diodes to isolate.. i'll see if i can find the exact info again
Powermyster
Silver - Posts: 962
Posted: July 08, 2005 at 6:10 AM / IP Logged
yeah i was just looking there again.
its a seperate wire and you just split your unlock output to go to both wires use diodes.
the diagram i got used a relay to isolate but i'd say you'd get away with just splitting and using diodes
thepencil
Gold - Posts: 1,526
Posted: July 08, 2005 at 9:05 AM / IP Logged
Do a search using the top right coner button.
Be careful whose advice you buy, but be patient with those who supply it.2002 toyota tacoma car security - Last Post -- posted image.
jpet1192
Member - Posts: 15
Posted: July 11, 2005 at 11:09 PM / IP Logged
jpet1192
Member - Posts: 15
Posted: July 11, 2005 at 11:10 PM / IP Logged
Thanx for the info. would you know what wire it is. so far I have not noticed any problems.
CutDog504
Silver - Posts: 643
Posted: July 12, 2005 at 1:52 AM / IP Logged
Some kinda way, if the child safety locks are engaged and you try to unlock the doors with yer alarm, they wont unlock(or so I've heard). I've had to deal with this on several Camrys and Corollas. All I do is split the unlock output (like a "Y") and put two diodes inline with the stripe side on the alarm side of the "Y". The child safety lock wire is usually ble/red or blue/black and is in the same wiring harness as the lock/unlock wires. You can also look HERE for more detailed instructions.
jpet1192
Member - Posts: 15
Posted: July 14, 2005 at 5:55 AM / IP Logged
Thank you very much for the help. this site is awsome.
james
