01 Chrysler Sebring Coupe
pincky
Member - Posts: 25
Posted: November 29, 2002 at 1:43 AM / IP Logged
01 Chrysler Sebring Coupe - Last Post -- posted image.Hi My question is that my factory radio is a 1.5 din
is there anyway that a double din radio would fit??
example the 01+  Mitsubishi Eclipse look like it has a double din opeaning and there interior is the same as in the sebring..?? if i were to take the center panel off of a eclipse and put it on my sebring wouldi be able to install a double din sized radio in its place???
or would i be able to modify my excisting center plate for a double din sized radio?
thanks ! Vince
Sound Pressure
Silver - Posts: 711
Posted: November 29, 2002 at 1:46 AM / IP Logged
If it's only a 1.5 din and your trying to fit a double din in that hole you will have to do some custom fitting.
Sound Pressure
Platinum - Posts: 12,488
Posted: November 29, 2002 at 5:20 AM / IP Logged
The Mitsu is a double DIN and the Sebring is a 1.5 DIN, the opening on both vehicles are larger than the radio, so the 2 DIN will fit into the 1.5 DIN opening, but the trim piece will not. Custom work is needed for this as well as the brackets will need to be customized.
