air bag
Dead Eye
Posted: November 29, 2002 at 5:26 PM / IP Logged
I have a 1996 ford probe gt.The air bag's were stolen from the car, the problem is that the air bag light stays on all the time. i know i can remove the bulb but i don't want to do that. There must be a resistor i can install into the plug were the air bag was atttached. how does the system know if the air bag is hooked up or not? does it sence the resistence on the line if it does then a resistor can be installed.
life is to short so live it to the fullest.
djfearny2
Silver - Posts: 810
Posted: November 29, 2002 at 7:21 PM / IP Logged
there should be a fuse for the air bags either one for the light alone or one for both just take that out i mean it sounds like youdont have any , anyways so it would not make a difference.
Jon
Installer/Help Technician
---coral springs florida---
securinu
Silver - Posts: 772
Posted: December 01, 2002 at 11:10 PM / IP Logged
actually you should probably replace them you will need them when you least expect it.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
