AVN5435/Diversified
gspot35
Member - Posts: 18
Posted: August 03, 2005 at 10:12 AM / IP Logged
I just connected up my AVN5435 and I have poor radio reception.  I have a Nissan so I used a diversity antenna adapter.  Does anyone know the culprit here?  Just as an example I can scan forward and not pick up a single channel.
Thanks in advance
gspot35
Member - Posts: 18
Posted: August 04, 2005 at 12:19 AM / IP Logged
no one has a suggestion???
azdoi
Member - Posts: 17
Posted: August 05, 2005 at 12:24 AM / IP Logged
Make sure there isn't a power antenna lead that needs to be powered up, especially if it is a glass mount antenna.  If it is on the AM side, try pulling the antenna out of the Eclipse unit slightly, and it should work fine.
gspot35
Member - Posts: 18
Posted: August 05, 2005 at 9:59 AM / IP Logged
You are the MAN!!!  Thanks so much...
