Fuel Pump Relay
91blaze
Member - Posts: 27
Posted: December 02, 2002 at 2:13 PM / IP Logged
in my 91 s10 blazer the fuel pump continues to run for up to about 10 seconds after i shut it off. it did this before i replaced the fuel pump cuz it went out. i was just wondering if id be ok using a regular bosch relay instead of spending  $10 at autozone on one cuz i have a bunch sittin around. i take it its possible for a relay to stick on for a few seconds like i think mine is doing? thanks for your replies.
alarmpro
Copper - Posts: 110
Posted: December 03, 2002 at 4:50 PM / IP Logged
how much do you want for those relays you have sittin around????
email me pelon072@yahoo.com
http://www.carstereo.com/members/alarmpro/
91blaze
Member - Posts: 27
Posted: December 03, 2002 at 5:17 PM / IP Logged
$53.47
alarmpro
Copper - Posts: 110
Posted: December 03, 2002 at 10:23 PM / IP Logged
$53.47 ???????????
What is this suppose to mean/?????
how many / what type / used or new????????????
red beard
Member - Posts: 11
Posted: December 06, 2002 at 8:47 AM / IP Logged
The fuel pumps on all GM products that I know of run for a few seconds after you turn the key off.  It is normal on a fuel injected engine.  One cause of those in the tankl fuel pumps going out is people running around with an almost empty tank.  The fuel pump needs fuel around it for cooling.  Every pump I know of that went bad, when the tank was pulled it was close to empty, coincedence, I think not.
Monday, September 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
