2005 G35 coupe VSS
corruption2k
Posted: August 17, 2005 at 11:17 AM / IP Logged
Hello, Installing a racing computer that needs the vss (speed sensor).  Need to know if I can find this wire coming from the cluster and the color.
Car is a 2005 Infinity G35 Coupe
Any help would be greatly appreciated.
Regards,
C2K
thepencil
Gold - Posts: 1,526
Posted: August 17, 2005 at 12:57 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - INFINITI / G35 COUPE / 2005 / Accessory
12volts WHITE/ blue (40A)   +   ignition harness
Ignition BLACK/ red   +   ignition harness
Parking Lights+ RED / blue   +   driver kick, harness to rear
Parking Lights- N/A
Headlight RED / black (L), red (R)   +   lights or IPDM E/R, gray 16 pin plug
Notes: The IPDM E/R (Intelligent Power Distribution Module Engine Room) is between the passenger fender and the battery.
Trunk/Hatch Release pink   -   BCM, pin 30
Notes: The BCM (Body Control Module) is in the driver kick panel.
The trunk release motor wire is GREEN / WHITE (+) at the BCM, pin 68.
Power Sliding Door N/A
Speed Sense WHITE/ green   2P   radio harness
Wipers purple (L), blue/black (H)   +   motor or IPDM E/R, gray 16 pin plug
LF Window up/dn see notes
Notes: Extended triggers on the power lock/unlock wires will roll the windows up/down. Use validity channels to control.
RF Window up/dn see LF window up/dn notes
LR Window up/dn N/A
RR Window up/dn N/A
Sun Roof open/close motor part of module
Sun Roof Limit/close N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models.
Be careful whose advice you buy, but be patient with those who supply it.2005 G35 coupe VSS - Last Post -- posted image.
