flush mounting 12's
05honda
Copper - Posts: 100
Posted: August 26, 2005 at 5:12 PM / IP Logged
I need to flush mount a 12" sub into the box I am making......what are the exact sies of the rings that i will need
Any help would be nice.....thanks
elmaschingon_18
Member - Posts: 21
Posted: August 26, 2005 at 5:31 PM / IP Logged
Hey Auther,
tell you the truth, your gonna have to measure the diameter of the subs. Basically all subs are different because of design preference by the manufactor. Or find someone on the forum that has made rings before of the same woofer.
happy glassin'
sanding sucks!
05honda
Copper - Posts: 100
Posted: August 26, 2005 at 9:13 PM / IP Logged
Thanks for the input.....in that case has anyone made rings for 12" kickers......
Clif
Member - Posts: 46
Posted: August 27, 2005 at 2:04 AM / IP Logged
you will need to make 2 rings, one for the sub to screw to and one that will go around the sub to make it flush. If you look in your manual for one of your subs, it will tell you your outer diam. just ad about an 1/8th to a 1/16th of and inch all the way around for propper clearence. and glass or resin or glue your rings together. and bam you got them flush mounted!
hmmm.... was that the right wire?
