alphasonik amp
ssnds
Copper - Posts: 169
Posted: September 20, 2005 at 8:10 PM / IP Logged
looking at a class D alphasonik. PMA1200 DA.   its for about $500. question is. lets see..
2400 watts RMS at 1ohm mono
is that a true 2400 watts? and the amp is 1ohm stable. the THD is <0.08%
Common Features
• Linkable with Second Identical Model (Hardware Included)
• Hour Meter
• Remote Mount PMA100V Digital Volt Meter
• Remote Mount PMA10B Bass Boost Control
• Heavy Duty One-Piece Extruded Aluminum Heat Sink
• Beveled Clear Acrylic Protective Cover
• Tiffany-Style RCA Jacks
• Parallel Line-Out RCA Jacks
• Removable Aluminum Side Covers Conceal Control & Terminal Panels
• MOSFET High-Speed Switching Power Supply
• Milspec Double-Sided Glass Epoxy Circuit Board w/ Through-Hole Plating
• Heavy 4 oz. Pure Copper PC Traces at All Preamp & Amplification Stages
• Internally Mounted Fan-Cooled Power Supply
• Solid Brass Nickel-Plated Terminal Blocks (4-Gauge Power, 8-Gauge Speaker)
• Variable Low-Pass Filter: 50Hz - 150Hz @ 24dB/Octave
• Variable Subsonic Filter: 15Hz - 40Hz @ 24dB/Octave
• Variable Bass Boost @ 45Hz: 0 - +18dB
• Variable Phase Shift: 0 - 180°
• THD: <0.08%
• Signal-to-Noise Ratio: >100dB
• Frequency Response: 5Hz - 250Hz
• Input Impedance: 10kŮ
• Input Sensitivity: 300mV~8V
• 4-Way Protection Circuitry: Thermal, Short Circuit, Overload & DC Offset
• Cooling Fan(s)
those are the specs from alphasonik.com anyways.. should i go with something like that or something like JL Audio 1000x1 or what? or maybe even a hole alpine system. i was thinking about gettin the alphasonik PMA1200 and two of the new 900series subs they have comin out. i can get those for like 275 each. any feedback is greatly appreciated.
thanks
b.t.w. i have a Alpine D310 dvd player (head unit) with a ps2.
SSounds
dwarren
Posted: September 20, 2005 at 8:39 PM / IP Logged
Why don't you try this link for starters. https://www.the12volt.com/installbay/forum_posts.asp?tid=62621&PN=2
Hopefully you will get something from thisalphasonik amp - Last Post -- posted image.
hoaxs
Copper - Posts: 95
Posted: September 20, 2005 at 11:32 PM / IP Logged
but it has an hour meter
Hurry get me a steel hanger, elec tape, zip ties, a monkey and a snorgle. trust me i've ran wires with less
dwarren
Posted: September 20, 2005 at 11:36 PM / IP Logged
Yeah!! What the heck is that? LOL!
Saturday, July 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
