is this sub worth repair?
41thermal
Member - Posts: 7
Posted: September 21, 2005 at 3:49 PM / IP Logged
hey guys, i recently got a used mmats 12" audio sub and an xtant 121m amp for $90. i found that the foam surrounding on the sub has split and is there anywhere that sells the fix for this? i cant seem to find it. i did a search for some things on this forum but didnt find anything. Thanks for the help!
Pioneer Premier DEH-P760MP
1X Alpine Type-E 12"
1X MTX RT-202 Amp
1 Pair 6X9 JBL GTO
blackmica3
Copper - Posts: 128
Posted: September 21, 2005 at 7:02 PM / IP Logged
41thermal
Member - Posts: 7
Posted: September 21, 2005 at 8:20 PM / IP Logged
Thankyou! is this kit east to use?
1X MTX RT-202 Amp
1 Pair 6X9 JBL GTO
stevdart
Platinum - Posts: 5,816
Posted: September 21, 2005 at 9:02 PM / IP Logged
No, it's not easy to do...but it's made for the do-it-yourselfer.  Follow instructions, prep the area like it says to do, take your time, be exacting.  This is foam surround as used in home audio systems but it will last awhile in a car until you can upgrade your equipment, perhaps...
41thermal
Member - Posts: 7
Posted: September 21, 2005 at 9:10 PM / IP Logged
will it be effected if i already put some rubber cement over the area? and is this a full foam surrounding or just the repair piece?
1X MTX RT-202 Amp
1 Pair 6X9 JBL GTO
stevdart
Posted: September 21, 2005 at 9:34 PM / IP Logged
http://www.partsexpress.com/Tech/260-915.html
It's all there in the link blackmica gave you.
41thermal
Member - Posts: 7
Posted: September 23, 2005 at 11:19 PM / IP Logged
Thanks ill be ordering it soon. But i have another issue, when my woofer pounds it sound like it is upagainst my trunk but it is atleast a foot away it sounds as if its hitting something bit its not. any suggestions? Thanks!
1X MTX RT-202 Amp
1 Pair 6X9 JBL GTO
hoaxs
Copper - Posts: 95
Posted: September 24, 2005 at 6:00 PM / IP Logged
its propley rattling your trunk real bad try some sound deading
Hurry get me a steel hanger, elec tape, zip ties, a monkey and a snorgle. trust me i've ran wires with less
41thermal
Member - Posts: 7
Posted: September 25, 2005 at 12:35 AM / IP Logged
ehh dust cover came off.
1X MTX RT-202 Amp
1 Pair 6X9 JBL GTO
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
