factory alarm, 92 Buick Park Avenue
muaiad97
Copper - Posts: 207
Posted: September 28, 2005 at 8:38 PM / IP Logged
hi all
anyone  can tell me  how to disconnect  thr  factory  alarm on buick  park  avenue  1992  i want  to install  new  alarm  . becaus of the factory alarm is on the car is not  starting with the key on  run but ther is no start so i thaut my be its the factory  disarm wire.
thanx
mo12v
Posted: September 28, 2005 at 8:53 PM / IP Logged
OEM Alarm DisarmLIGHT GREEN(-) AT EITHER KICK PANEL
RKE ModuleBEHIND RIGHT SIDE OF DASH ABOVE GLOVE BOX
MO
fingaz22
Silver - Posts: 410
Posted: September 28, 2005 at 9:35 PM / IP Logged
your car has a resistor in the key right? if so you will not be able to bypass because it is tied right into the power train module (computer) only if you have the pellet in the key. if this is the case then you will need to replace then ignition switch key cylinder. they get worn out in side and lose contact with the pellet. i've had to do three this month alone. if you have anyother question pm me
JUST ONE MORE AMP!!!
hu,alpine cva 1005/dva 5205
sound processor,symmetry(first one).
sub amp,power 1000 the terminator.(1992).
subs,spl comp dual 1 ohms.
punch 150hd on a 10" ev.
alotofhighs
muaiad97
Copper - Posts: 207
Posted: September 28, 2005 at 9:44 PM / IP Logged
thanx  for  replay  yea the key still the original one and ther is resistor in the key
fingaz22
Silver - Posts: 410
Posted: September 28, 2005 at 9:51 PM / IP Logged
you can get the cylinder at a local lock smith. when you install it you will have to cut the wire at the junction block near where your feet rest above the brake pedal. just make sure you soldier you connection. it dont matter what way the two wires go seeing that it is a resistor.(no polarity). lol
alotofhighs
