2001 Sequoia rear defrost trigger?
furious440
Member - Posts: 8
Posted: October 20, 2005 at 8:59 AM / IP Logged
Hi anybody!  I wondered if anyone on this board has a good meathod for triggering the rear defrost on a Sequoia?
I assume I will just need to find the wire that activates the factory relay and pulse it. Or is it more involved than that?
Thanks for the post and to all who reply!
thepencil
Gold - Posts: 1,526
Posted: October 20, 2005 at 11:38 AM / IP Logged
Normally, a diode to the ground out when running is all that that will be use in combination with the Accessroy wire to activate the defrost.
Be careful whose advice you buy, but be patient with those who supply it.2001 Sequoia rear defrost trigger? - Last Post -- posted image.
kgerry
Platinum - Posts: 3,455
Posted: October 20, 2005 at 2:30 PM / IP Logged
you'll have to determine the polarity of the circuit, as well as whether it's a pulsed or latched circuit... many RS units today have a dedicated defroster output that is programmable....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
furious440
Member - Posts: 8
Posted: October 20, 2005 at 7:22 PM / IP Logged
Thanks for everyone!  I just looked at the Toyota wiring diagram and I will use the latched output from my remote start. And I will use a diode to isolate.
However, I wish I could activate the front defrost as well. This vehicle has auto climate with one touch front defrost. Unfortunately,  it is all multiplex communications and no switch that I can directly connect to.
thepencil
Gold - Posts: 1,526
Posted: October 20, 2005 at 8:36 PM / IP Logged
Is there not a fan for the front windshield which will do that?
furious440
Member - Posts: 8
Posted: October 21, 2005 at 1:44 PM / IP Logged
Yes, there is of course the blower for the front. I just wish there was a way to activate the front defrost (e.g. heat on high, fan on high, DEF vents) by remote.
Chris Luongo
Platinum - Posts: 3,746
Posted: October 22, 2005 at 7:32 AM / IP Logged
As a compromise, for the front defrost, you might do this:
First, set the climate controls to Auto, and set the temperature the way you want it.
Next, hit the button that changes where the air comes out----set it so that it comes out the heater and defroster vents at the same time.
As long as you don't touch anything else, the system will still regulate the fan speed and air temperature automatically, so you'll always be comfortable...... but when you remote start, some air will reach the windshield and warm it.
furious440
Member - Posts: 8
Posted: October 22, 2005 at 3:52 PM / IP Logged
Well, I am already used to presetting the climate controls but I think I'm going to go for it and see what mods I can make to HVAC contol panel circuit board aka A/C amplifier.
BTW: Thanks Chris Luongo for your previous posts on the Sequoia. Very helpful!!
