starts then alarm goes off?
dougie109
Member - Posts: 25
Posted: October 28, 2005 at 4:12 PM / IP Logged
carvox king eagle... please never buy it.. go with a proper alarm/keyless/start
the alarm goes off after engaging the engine then does a emergency shut down then pages me..
this only happens when the engine is cold. any idea at all? ive tried everything lol
Regards
infinkc
Copper - Posts: 438
Posted: October 28, 2005 at 4:16 PM / IP Logged
type of car?
dougie109
Member - Posts: 25
Posted: October 28, 2005 at 4:25 PM / IP Logged
2000 focus wagon
Douglas
Alpine Guy
Platinum - Posts: 2,478
Posted: October 28, 2005 at 10:50 PM / IP Logged
which alarm goes off? the factory alarm or the aftermarket alarm?
dougie109
Member - Posts: 25
Posted: October 29, 2005 at 9:42 AM / IP Logged
the aftermarket one
infinkc
Copper - Posts: 438
Posted: October 29, 2005 at 10:15 AM / IP Logged
you might want to set the tach signal for the alarm when the car is cold, do you know what trigger is getting set off? is so you can bypass that sensor/trigger when the remote start is active
dougie109
Member - Posts: 25
Posted: October 29, 2005 at 2:09 PM / IP Logged
how do i set the tach speed? i dont understand.. regards
dougie109
Member - Posts: 25
Posted: October 30, 2005 at 10:53 AM / IP Logged
ok.. well it says nothing about that.. lol.. sounds soo right tho.. cause it would sense that right away and the voltage would be high... is there a way to manually set it? example unplug the whole unit when cold and start it from the auto start? or anything like that.. regards
dougie109
Member - Posts: 25
Posted: October 30, 2005 at 1:18 PM / IP Logged
is there a way for me to regulate the voltage myself? like place a series of resistors into the circuit to let a maximum voltage of like 2.5 or something through? or is that a bad idea? beacuse the unit doesn;t look at all like it can be programmed.. says nothing about it in the book. thanks again
Douglas
Saturday, July 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
