2006 ram diesel remote start
Nate_Dogg
Member - Posts: 35
Posted: November 01, 2005 at 12:20 PM / IP Logged
I'm having trouble with intergrating a black widow
remote start.1st:alarm and start works but it is throwing
codes everywhere.I 've cleared the codes but there is
still a TCM (transmission Controller modual)problem.
I think it might be an induced voltage somewhere,coming
from the alarm wiring,but not positive on that.
Chrysler Tech.
Clarion dealer
Black Widow,Ungo alarms.
General electrical
Moderator - Posts: 12,488
Posted: November 01, 2005 at 12:32 PM / IP Logged
Did you isolate the 2nd starter wire with a relay and use a 180 ohm resistor for the 2nd starter wire to negative ? You also have this wire act as an accessory wire through a relay (-) trigger through a 610 ohm resitor.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 01, 2005 at 1:14 PM / IP Logged
Posted: November 01, 2005 at 4:32 PM / IP Logged
Yup
Thursday, July 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
