no power on head unit
silverado94
Member - Posts: 25
Posted: November 01, 2005 at 7:31 PM / IP Logged
i have a 2002 ford windstar which has the am/fm/cd stereo . about a week ago the battery went dead and we jumped the car to get it running . well upon turning the radio back on it didn't . no radio or cd or clock i've checked for a fuse on the block and it's not there . even the alarm doesn't set so i'm wondering if the alarm and audio system is on the same fuse . maybe the stereo got spiked on the jump and hit the alarm system at the same time . is there a fuse on the rear of the head unit and how do i fix the alarm .
sparkie
Platinum - Posts: 2,061
Posted: November 01, 2005 at 7:35 PM / IP Logged
Recheck your fuse block for a blown fuse. Your van probably has two fuse panels. One under the dash and one underhood. The fuses usually aren't lableled in Fords, so it may be a good idea to check them all with a 12 volt test light or volt meter.
sparky
pss5075104
Copper - Posts: 144
Posted: November 01, 2005 at 8:31 PM / IP Logged
normaly the block under the hood will have the constant power and the one under the dash will have the switched.
D
MECP First Class Certified Installer.
Nothing is impossable, it's just more expensive.
menace2sobriety
Silver - Posts: 394
Posted: November 02, 2005 at 4:20 AM / IP Logged
ford fuses are labeled in the owners manual. bob
steezs
Copper - Posts: 172
Posted: November 03, 2005 at 4:38 PM / IP Logged
DID you jump it like shown in this diagram http://www.vcoa.org/700-900-faq/ElectricalStarting.html#Starter_and_Solenoid_Problems or did you do direct negative to negative on the batteries that cause problems maybe screws your radio and everything
the duce
steezs
Copper - Posts: 172
Posted: November 03, 2005 at 4:39 PM / IP Logged
