Drop down video install in a 2002 Suburba
dag5000
Posted: May 08, 2002 at 9:07 PM / IP Logged
I plan to install a drop down lcd unit in my 2002 suburban. The unit came with wiring diagrams which are straightforward enough. I am putting the unit where the existing dome light sits, can I take my +12V power from the dome wiring or must I route in through the headliner to the fuse block. The instructions are unclear.
Dave G
Platinum - Posts: 12,488
Posted: May 09, 2002 at 1:28 AM / IP Logged
I would run a wire from the fuse box to the LCD monitor . This will ensure a clean and trouble free connection to the LCD monitor and also fuse this connection even if it is still connected to a fuse in the fuse box.
XtremeMachines
Member - Posts: 9
Posted: May 09, 2002 at 12:53 PM / IP Logged
If you do use the dome light wire, make sure that it doesn't turn on when the doors are opened or the interior lights are on.
