Do i need another inline fuse?
AJRXtreme
Silver - Posts: 302
Posted: December 15, 2005 at 2:23 PM / IP Logged
ok right now ive got a 350amp inline fuse from my battery under the hood. I wanted to know sinc ei was running another battery in the back of my car should i run another inline fuse after the second battery? or should i run the fuse i have now after the second battery and not between the first and second batteries? Thankyou
03 F150 on 24's
HU:Pioneer DVD5700
Frt:MC57
Subs:(12)S12L7
Amps:(3)KX2500.1's, MC-2004
j_darling2007
Copper - Posts: 210
Posted: December 15, 2005 at 2:45 PM / IP Logged
You want to fuse (or use a circuit breaker) within 18" of each battery.  If the wire shorts in the middle, you have to have protection (a fuse) near both batteries.
There are 3 kinds of people in the world, those who can count and those who can't
auex
Platinum - Posts: 5,041
Posted: December 15, 2005 at 6:31 PM / IP Logged
You should fuse every input/output going into the positive terminal of any battery within 18 inches. Including if you add a second one in the trunk.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
oxygen65
Silver - Posts: 252
Posted: December 15, 2005 at 11:30 PM / IP Logged
what the hell do you have in your car that is causing a 350 amp draw?
i hope you have a high output alternator too.
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
