Gentex Mirror, mistake?
czsteve
Posted: December 17, 2005 at 2:08 PM / IP Logged
Hello,
Doing my due-diligence before following up w/ an ebay purchase.
I Just received a gntx-177 that was listed as having the compass, temperature, and auto dimmimg features along with the temperature probe.
I just received it today and the mirror only has the buttons 'compass / mirror'. My understanding is that it should say 'comp/temp' if had the temperature feature.
The attached pigtail is 5 wires out of the possible 7 pin options on th back of the mirror.
1 = pink w/ black stripe
2 = black w/ white stripe
3 = green
4 =gray
5 = pink
6 & 7 are empty.
My understanding is the pink/black = 12v hot, BLACK/ white = ground, green is for back-up circuit, gray & pink are for outside dim, and pins 6 & 7 would be for temp if applicable.
I just want to make sure I'm understanding this correctly before engaing w/ the seller.
BTW: the mirror was supposedly from a '98 Buick La Sabre.
The two wires are from the temp probe: black w/ white stripe & green w/ black stripe.
Gentex Mirror, mistake? - Last Post -- posted image.
Thanks,
Steve
boomer_106
Silver - Posts: 710
Posted: December 23, 2005 at 2:15 PM / IP Logged
Hey Steve I would give gentex a call.
http://www.gentex.com/contacts.html
Also I found this here at this site.
Posted: February 26, 2003 at 7:13 AM - IP Logged
Here is the low down on the connections to a Gentex mirror (with comp and temp) cut from a late model GM product. The connector pin numbers are found on the wire incursion side of the mating connector.
                          GM wire harness color                  function
PIN 1                  PINK                                                 POWER +12 volts
PIN 2                   BK                                                    CHASSIS, GND
PIN 3                   LT GRN                                           BACKUP LIGHTS
PIN 4                   GY                                  TO AUTO DIM OUTSIDE MIRROR
PIN 5                    PINK                              TO AUTO DIM OUTSIDE MIRROR
PIN 6                    DR GRN/WT                                  TEMP PROBE
PIN 7                    BK/WT                                             TEMP PROBE
Note: Pin 3 is to be connected to the backup lights to turn off the auto dim feature in reverse. If you intend not to use this feature connect the LT GRN wire to chassis ground. If this pin is floating the auto dim will not work properly. Hope this helps.                             Walt
I'm thinking you're right that it should have the temp and compass buttons but, I am not for sure. That's why I would try calling gentex themselves
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
