Blue Tooth
avs1
Posted: January 01, 2006 at 9:59 AM / IP Logged
I have a Acura RL 2004 and just bought the Verizon V3 Razor Blue Tooth phone. My car has a Navigation system, satellite radio and is On-Star capable. I'm getting a different story from every installer I speak with to what I would like to do and what's possible. I would like to buy the Motorola IHF1000 (some say no I should buy the HF850 because the 1000 doesn't work with Verizon's Razor and others say that's not true. I would like to have the unit installed into my car so that the volume up/down works from my steering wheel control, the radio mutes on receiving a call, use my On-Star microphone and the speakers that are already in the car instead of the external one that is usually supplied. My brother has a GM trunck and all the above work just fine with it. Some say it's because I have an Acura and others haven't done that before so just don't believe it can be done.
Looking for the truth.
techguy688
Copper - Posts: 55
Posted: January 26, 2006 at 9:51 PM / IP Logged
The truth is anything is possible. If you want to spend a lot of money and time on your project.. It sound like an integration nightmare. I dont believe ther is quick install fix to your idea. Find an installer who is willing to spend the time on a custom install, not a quick, i only install radios, speakers, and satelite radio shop. Be prepare to spend $$$.   OR Google you way to available parts and equipment. Blue Tooth - Last Post -- posted image. Blue Tooth - Last Post -- posted image.
Just because you've done something for a long time doesn't mean you're any good at it.
Cable Ties Rock!
KarTuneMan
Platinum - Posts: 7,056
Posted: January 26, 2006 at 10:39 PM / IP Logged
avs1. Try and contact someone here... http://peripheralelectronics.com/web/blnc.asp
you WILL get the truth!!!
You can vote in polls in this forum
