2003-2004 ram 2500 radio removal
draasch
Gold - Posts: 2,172
Posted: January 12, 2006 at 3:34 PM / IP Logged
does anyone know how the radio comes out on this truck????
thanks,
david
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
sparkie
Platinum - Posts: 2,061
Posted: January 12, 2006 at 4:55 PM / IP Logged
As far as I can remember their is only one screw below and to the right of the radio inside a pocket. The rest of the plate that surrounds the radio and cluster is held in by clips. Pull the plate towards you to disengage the clips. You can then remove the 4 screws holding in the radio and pull it out.
sparky
ohlarikd
Copper - Posts: 56
Posted: January 12, 2006 at 9:23 PM / IP Logged
YEP!  I have an 05 Ram 2500.  One screw inside the hook at the lower right corner of that bezel.  Take that out, then gently pry around the whole bezel.  It actually comes out with not much force, so nothing should break.
Derek
Tuesday, July 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
