93 Buick Skylark Remote Start Info
tankisarockstar
Posted: January 17, 2006 at 3:07 PM / IP Logged
I have a 93 Buick Syklark with an aftermarket Viper alarm. I want to put the Valet 562T remote start in myself..anyone have the proper wiring diagrams?
ahdol
thepencil
Gold - Posts: 1,526
Posted: January 20, 2006 at 8:57 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - BUICK / SKYLARK / 1993 / Remote Start
12volts red    +   ignition harness
Starter yellow    +   ignition harness
Second Starter
Ignition pink    +   ignition harness
Second Ignition pink/white    +   ignition harness
Third Ignition
Accessory orange    +   ignition harness
Second Accessory
Keysense
Power Lock lt. blue    +   drivers kick
Power Unlock black    +   drivers kick
Lock Motor
Unlock Motor
Parking Lights+ brown      light switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger white    -   courtesy lt, pinswitch
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release black    +   release switch
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer PURPLE / white   AC   distributor/coil pack
Notes: Some coil packs rear of engine above transaxle.
Wait to start
Brake Wire white    +   brake switch
Parking Brake
Horn Trigger black    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.93 Buick Skylark Remote Start  Info - Last Post -- posted image.
