saturn third ignition
crash2ny05
Member - Posts: 7
Posted: January 26, 2006 at 4:52 PM / IP Logged
i have a 2001 saturn L200 i need to hook up the third ignition wire for my remote start i think i know what wire to use in the car my ? is how do i hook up the relay for this the install book dont tell you
thank yousaturn third ignition - Last Post -- posted image.
crash2ny05
kohara73
Copper - Posts: 192
Posted: January 26, 2006 at 5:15 PM / IP Logged
pin 85=ground out when running from your remote start
pin 86=1st or 2nd ignition wire
pin 30=+12V
pin 87=3rd ign. on your car
Keith
mo12v
Posted: January 26, 2006 at 5:16 PM / IP Logged
Should have only 2 Ignitions
Constant 12 voltsREDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Ignition #2GREENIGNITION SWITCH HARNESS
AccessoryORANGEIGNITION SWITCH HARNESS
AccessoryBROWNIGNITION SWITCH HARNESS
MO
crash2ny05
Member - Posts: 7
Posted: January 26, 2006 at 6:33 PM / IP Logged
third ignition (key sense) must see ground during remote start to keep service light off. kohara73 the relay you have iam lost on pin 86saturn third ignition - Last Post -- posted image.
crash2ny05
nstaller36695
Copper - Posts: 106
Posted: January 26, 2006 at 7:54 PM / IP Logged
so whats the problem the engine light keeps coming on when u crank it ? and is that why u are asking about a third ignition ?
the best part of a job is seeing the bumper get smaller over the horizon
nstaller36695
Copper - Posts: 106
Posted: January 26, 2006 at 7:58 PM / IP Logged
sorry i just reread if the key sense has to see ground. what u need to do is look at the directions and see if there is a 3rd ignition wire output from the alarm harness. it should be a smaller wire and that will send out a low amp negative signal and i would definitely diode isolate it.  and hopefully no relay needed. this should help
Chris Luongo
Platinum - Posts: 3,746
Posted: January 26, 2006 at 9:18 PM / IP Logged
Saturns only have two ignition wires.
What is it you are trying to do?
Does your L have manual or automatic climate controls?
Tuesday, July 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
