99 Grand-Am with DEI 555L
brcidd
Copper - Posts: 274
Posted: February 11, 2006 at 6:59 PM / IP Logged
Last time this happened to me- I found the power to the bypass DROPPED OUT during crank- It was an accessory, not an ignition wire- the R/S was not set right from the factory- had to move the jumper inside....just a thought you need to make sure your bypass is powered during crank as well....
Brcidd - Engineer That Does Remote Starter Installs on the side.
streetdream
Member - Posts: 22
Posted: February 11, 2006 at 8:33 PM / IP Logged
Just do it the old fashioned way with a resistor and relay. This way even if the relay goes bad the car will still start. Can't tell you how many 555L/556L I have thrown away in my life because they went bad after prolonged use and the customer's vehicle wouldn't start.
MECP First Class
Bay Manager
