New to the Relay world
gmc4x4
Copper - Posts: 62
Posted: January 01, 2003 at 1:06 PM / IP Logged
Ok I must admit I was totally blown away with all the stuff you can do with a relay after cruising this site for hours..My question is this>>>>>>>
Is it OK to splice into a wire if you are adding something or should you use a relay to splice the power??
Sorry if this is a stupid question, just after reading all this relay stuff, it was just something I was wondering about....
the12volt
Administrator - Posts: 3,957
Posted: January 01, 2003 at 1:46 PM / IP Logged
Hi Sean, it will depend on what you're tying into. Did you have something specific in mind, or just in general?
gmc4x4
Copper - Posts: 62
Posted: January 01, 2003 at 1:57 PM / IP Logged
..in general for the most part. I mean I am a splicing fool New to the Relay world - Last Post -- posted image. And after reading some of the nightmares that have happened to people burning things up, I just wanted to be more cautious on what i do.
so for an example lets say for hooking up off road lights. If you were hooking up 4 150watts lights..what would you do?
the12volt
Posted: January 01, 2003 at 2:41 PM / IP Logged
I'd run an additional fused power lead from the battery to a relay, then activate the coil of the relay via a switch to send power to the road lights instead of attempting to splice the power lead of the road lights into the power lead of some other lights such as your parking lights or head lights. You could even have the coil of the relay activated by the parking lights or head lights or by some other existing switch if you didn't want to add one.
gmc4x4
Copper - Posts: 62
Posted: January 01, 2003 at 2:55 PM / IP Logged
thanks for the input...I am a the12volt.com junkie now... I think I check and read posts on this site more than my email....thanks for all the great info, and taking the time for my questions!!!
later
the12volt
Posted: January 01, 2003 at 3:01 PM / IP Logged
You're welcome Sean, glad I could help ;)
