2007 Escalade Dash Removal?
Fastlearner
Silver - Posts: 346
Posted: April 01, 2006 at 3:52 PM / IP Logged
Has anyone done this before. Just looking for some tips to get the center dash off. I'm installing a hands free kit.
Ween
Platinum - Posts: 1,368
Posted: April 01, 2006 at 5:50 PM / IP Logged
hi,
the lower center console woodgrain part pulls straight up.  the woodgrain dash pulls straight back.  both panels held on with metal clips.  both pieces removed as a single piece but they are definitely separate.  pryed (panel tool)the dash piece first and then worked both sections off as a unit.  hope this helps.
mark
scottyv
Posted: April 18, 2006 at 9:32 PM / IP Logged
have you figured out how to overide the nav/dvd functions while driving??
It should not be too hard as it goes out when in put out of park
the 07 bose in the escalade is a new deck with 5.1 surround,
I am hoping I can add aftermarket amps to this and keep a factory head unit any
leads on this as well
scottyv
Posted: April 20, 2006 at 9:25 PM / IP Logged
Yep it is tranny specific.
Removed an un derhood trans contol fuse (marked #14 I believe under the hood)
DVD then worked in drive & out of park.........but I only had sixth gear & could not downshift!!
I'll get the dash apart soon enough & try to trace any wire that shows a change when out of park.
Could be in the class II bus though, if so difficult at best
SV
scottyv
Posted: April 20, 2006 at 9:28 PM / IP Logged
Ween, are you referring to a new 07 escalade or pre -07??  Is it as easy as my 03 was?? (Just pry carefully)
I want to get a diagram from dealer of expoded view of 07 dash before I dive in.
SV
